Hi,
thank you for your help.
My car can't accelerate cause it loose some retainers on the throttle body lever.
pics uploaded(i took the pics for ebay good state throttle body)
2001 LS V8
I search on ford part giant but not luck,also ebay,amazon,etc...
I found a retainer clips, they are like D or C shape, but can't fine the plastic part.
Aprecciate your help, thanks!
Short Story
I was driving so happy, full pressing and releasing the pedal accelerator until it stop responding, my first thought "The transmission" i pull over right away , the pedal feels different but not loose, i move the shift knob to D and the car started to move , then to R and move slow, i was trying to discover what happened, then i press again the accelerator pedal and the car did not anything.
So i opened the hood, everything looks good to me, no smoke, no liquids, no codes( I carry on obd scanner always xD)
I dont know why I pulled the accelerator cable and the car did not rev up, so i pull the other sided part , a closer one to the return spring and the car rev ups fine.
I discovered a hanging " C lever" , that part connects the accelerator cable to the throttle body but on my car it was disconected.
I took it apart and noted a brittle plastic which break apart instantly xD , it also has a " C or D retainer clips at the end, one of them went away, i was looky to not lose the C lever.
2001 LS V8
- Do you know if i can get the plastic and retaner clips only? or
- do i have to buy the entire throttle body? W_W
- What's the right part name?
- Any part number ?
Short Story
