Speedstar Lincoln Center Cap Special
Legend1
Jonesboro
After a lot of testing and a sell out of our initial run of Speedstar Lincoln Center Caps we have a new supplier and a great new price.
We are offering a Special new price of $11.99 for a complete set. They give the Speedstar wheel the right look with the correct center cap.
Take a look at TemplePerformanceCars.com
Thanks,
John
What's the diameter of the sticker? How thick is it? Do you have pics of them uninstalled?
Speedstar Center Caps
Hello everyone...our center caps are designed specifically for the replica Saleen Speedstar wheel and are 2.344 in diameter and less than 3/32 think in the center and taper to nothing at the edges. All you have to do is peel off the original thin metal cap from the original wheel caps and clean very well with alcohol or equivalent solvent then reapply the new center caps. You don't even have to pull the insert out of the wheel.
We make them from materials and adhesives designed for the outdoors and also to be fade resistant.
Thanks,
John
Any idea whether or not this will work on an LS?
... are 2.344 in diameter and less than 3/32 think in the center and taper to nothing at the edges. All you have to do is peel off the original thin metal cap from the original wheel caps and clean very well with alcohol or equivalent solvent then reapply the new center caps. You don't even have to pull the insert out of the wheel.
We make them from materials and adhesives designed for the outdoors and also to be fade resistant...
Not own a tape measure or ruler?
They are decals (stickers) so thought it was a simple procedure to see if they fit.
I don't want to hijack this thread so will leave it at that, and let someone else answer if they will fit...
Damn, my FR500s have 2.5" center caps. I might just buy these anyway and see if they'll be close enough to look OK.
Questions
I just wanted to answer some questions posted. First is whether they fit the LS and I would have to know the center cap diameter to answer that..if its 2.344 or slightly larger they will work.
As far as making caps with the emblem in black with a silver background I would have to have at least 30 paid orders to tool up.
Hope that answered everything ....Thanks john
Speedstar Caps
Hey everyone...My car has chrome speedstars with our center caps and they look great. Let me know if you need pics. Thanks...John
well if you need ppl to make some for the ls, count me in. I would need some in 2.5'' though.
How much would it cost to have only one set made for the ls if no one else wants a set?
