so, what am I getting my self into
topher5150
Grand Rapids, Michigan
I went to a couple of places to get guesstimates about my front suspension and both of them said my rack is on it's way out (checked Sears they wanted $728 parts and labor). I ordered a remanned rack and I'm curious how monumental a task is this going to be, and can I eyeball the alingment to get it to the shop
You can get a rack for around $100
$700+ for parts and labor is WAY too much...our racks are easy to R+R, if you have any knowledge of lefty loosey, righty tighty, we can walk you through it
note that Gen1 and Gen2 Racks are different...best rack for a gen1 is a 93, Gen2 = 98 ( if you get one out of a salvage yard)
As far as alignment, just count the threads as you remove the inner tie rod ends...make sure you remove the boot from the ends of the rack, which will expose the nut end of the inner rod, remove the safety pin from the inner tie rod end.
If you have trouble with the outter rods, just smack the knuckle where the joint is with a hammer, it'll pop loose
edit: just called Advance..I can get a 93 rack for $72.74 with exchange $20 core
94-98 have same part number ..$87.29 exchange, $20 core
my labor book shows 1.5 hours...
You tell me where the extra $500 for Sears is going
interesting... I always thought 93-97 were the same and 98 was a different rack.
When I did my k-member, the donor was also a 93, I used the rack that was already on the k-member, so it was an even swap, I'm not exactly sure where the difference lies as far as the years...but there are 2 different style racks in the Marks, and I know it has to do with where the bolts are in accordance with the k-member...meaning the distance between anchor bolts,
Best bet is to pull your rack, get the part # off of it
buy 4 bottles of PS fluid..and be ready for a mess
I don't even think the dealership would have charged that much. i got the reman from advanced auto it's a Cardone, with inner tie rods, for $89.99 with a $60 core. my biggest concerne is the rag joint, how exactly is it held on.
When I first bought my Mark VIII, before I began the real learning curve of basic mechanics, I took my car into a shop to get the ball joint replaced. They also told me that my steering rack was "on it's way out." That there was some slack and that I should start considering having it replaced. Back then, I didn't know better and they gave me what I considered an astronomical price.
It was bull:q:q:q:q.
It's been nearly 100,000 miles since that bastard told me I needed to replace my steering rack.
Unless YOU can feel that it's really on it's way out, or the guy at Sears is a close, personal friend that you trust with your life, DO NOT take their word for it.
Business is slow right now
I was once told that my steering rack needed replacing... in a car that didn't even have one! LMAO.
Ok ...lets try this...
How was it determined that your rack is "on it way out?
Have you noticed anything different in your steering, do you have sloshing steering? Does it make a clicking noise while you steer? Have you ever turned your steering wheel and the vehicle not react ?
Yeah, thats a bad rack.
If it were me I would buy Nolimits one as its a quick ratio 93 that was redone with OEM parts.... not some BS taiwan parts store crap.
And the differences are
93: Quick ratio
94-97: All the same
98: Different mounting points
93: Quick ratio
94-97: All the same
Will the 93's mount on the 94-97? I assume there's an advantage there.
Yes, only a 98 must have 98s rack because of the bolts locations..93-97 are all interchangable..but 93 have the best ratio
and just noticed nobody has answered your rag joint question..
There's a bolt (13mm?) in the racks yolk..take that bolt out..it can be reached easily on the driver side, go from behind the k-member and above it, once that bolt is out you can slide the steering shaft loose from the rack
I believe there is a pic of me taking this bolt out on my progress thread
93: Quick ratio
94-97: All the same
No worries it's a Mexi reman
