Quik LS said:yes - it is the best performance upgrade you can do for the dollar.
^Quik LS said:- it works for all LSes if SCT has your PCM code cracked
Quik LS said:there are many many threads on this - do a search on 'SCT Flasher'
- no it will not hurt the engine
- it is PCM code specific and VIN locked to you car - you cannot transfer it
- re-tuning has shown gains from 14rwhp+ on a stock LS
2001LS8Sport said:Quik...on the Diablo (for other cars), you can "unmarry" the tuner by reloading the tune back into the tuner and re-installing the factory tune. You can then use the tuner on another car (that has the right ECM, etc) Is that not the same on the SCT?
00_slow_5spd_ls said:so will the sct flasher work for the v6? if so where can i buy one
lloydrage said:questions:
if it doesnt hurt the engine why would you ever have it not set at max?
do you have to leave the flasher plugged in?
can you connect it without a labtop?
lloydrage said:so what should I set it at to be safe? I have a 02 LSE V6 auto
thanks for all of your help
lloydrage said:what do you mean by pings?
