Actually I have been thinking about this and wanted to run it by you guys. Electronics have been my specialty for over 20 years and I even automated a sugar cane boiler which is what made me think more about this. See we had a big spark plug to light a propane torch that would light a larger oil torch that would light the bagass torch. Needed progressively larger flames to light the higher flowing fuel torches.
On a car engine that is spinning past 5000 RPM there is enough air flow that it could blow the spark out even N/A. See the coil is firing so fast it cant fully charge so the spark is weaker and with the excessive air flow coupled with the lower energy could cause the plug to not ignite the mixture properly.
If its a tiny spark the mixture may start to burn but almost instantly burns out because its ignition wasn't hot enough to complete the burn.
You can get partial explosions, our cars shoot fuel out the pipes when they run perfect (very minute amount). That is unburned fuel that was in there when it went boom yet didn't burn with it.
Also with a large, hotter spark it can catch a greater area of the mixture at time of ignition theoretically causing the "complete" explosion to happen faster also resulting in a HP gain.
So now that I think about it a better coil will allow for a larger hotter spark at higher loads causing a better burn at higher RPMs and less chance of getting blown out.
Does that make sense or should I lay off teh weed? :lol:
