RigsLS
- Joined
- Mar 10, 2012
- Messages
- 7,756
- Reaction score
- 532
I might be wrong, I thought I read "silencer".
It figures, I was looking at it from all angles like "Well That's Fantastic (WTF) is the point of this thing?" It does look like something to choke the intake of air a bit in order to eliminate resonance or something. joe, you have any idea what purpose it might serve?
LOL ... now that's funny.
RE: "Upon starting after installation (battery), I did not get any stuttering or rough idle I am used to.
It may have been a fluke, but could this have been a voltage issue in any way?"
May very well be, we all know that when disconnecting the battery for a period of time,
on re-installation it needs to relearn the idle air mixture rate and such.
It will do this on it's very own.
By checking the air intake plenum I meant check the underneath side of the silencer right at the front on top
of the radiator. I've seen someone post a pic here where the underneath side had a crack along the seam.
I had looked for the picture but couldn't find it.
Hopefully this will be the end of your troubles.
Although we tend to give member "jrand" a hard time about his recalibrating procedures, when disconnecting
batteries, there is some truth to it, only it's suggested the LS does it on it's own during a few drive cycles.
It's in the shop manuals for the reason for the tech to have it done by the time customers pick their cars up
and to ensure during test drives, all problems are resolved.
Yea youre probably right. I almost expect the issue to come back after a couple startups.
The silencer has no cracks in it. I cleaned and inspected it thoroughly when I did the work outlined in this thread on March 3rd. I didn't know that's what that thing was called!![]()
shaking your head up and down in agreement. good for you littlerig<shakes head again>
jrand, that drive calibration thing can't be followed in Austin, Tx. I try to follow it as close as possible but it usually ends with me having to decide to either run this red light or break the calibration steps. I go through the calibration over a couple days, making sure to complete as many steps consecutively as possible.
I don't know just where he got "drive calibration" calibration instructions, but I can tell you I have never had to do such a procedure on any of the many, many cars I've owned. You might even be surprised to know that at the factory the cars are driven off the line onto a dyno and then floored for almost a minute! I almost lost it watching that!
