Okay... for those of you that don't know I have the DBRU full 13" brake kit all the way around on my car...
I was having issues with the noise they were making... lots of grinding, caliper, pad noise and such. I had to run a :q:q:q:qty spacer when I first installed them to get them to clear the rims but now that the pad has worn down enough I was able to remove the spacer...
That solved alot of my problems and I figured out why the rears are making noise as well...
The rear rotors are the same as the front and have the same inside mounting hub diameter... so the rotor has play around the hub. Now Kid and I were talking and I guess I was wondering too if I swap to the mustang rear hub will it be as big as the front? I don't see why it would be...
If thats the case and it wont solve my problem why in the hell didn't DBRU send a hubcentric spacer???
Kid said i could get one machined but we are talking some ching... Let me know guys
