kfisher777
I needed to fix a crack on my degas bottle (2003 LS V8) and now Im not able to reinstall the bottom hose of the tank. Its not long enough to reach and put the clamp on it. Any ideas on how to install this? Thanks!
jack car up, remove drivers side front wheel then remove the plastic wheel well panel. You will see holes in the sheetmetal of the wheelwell which allow access to the hose/clamps
that hose can be disconnected about mid-point under the cowl and you can pull it out - then attach it to the bottom of the bottle, then feed it back into position and reconnect
