93mkviii
Well my compressor for the a/c and fan aren't turning and and causing overheating issues. I took it to a mechanic and he told me the connector is getting power and the fan motor is bad. He said hitting the motor made it work like a starter but it's a temporary fix. Does this mean i really have a bad fan motor?
Also, for the replacement fan motor i've done some research and the old mounts need to be shredded and bolts need to go in right? I've got this motor in mind to replace the original. http://shop.advanceautoparts.com/we...r_19010389-P_564_R|GRPCOOLAMS_____#fragment-2 Will it work? How does this attach to the fan? Does the spindle pop in and out of the fan? If anyone has replaced a motor before any help would be great. I've also tried messing with the connector but no avail and it seems already pretty tight.
