Radiator change steps and advice?
I never said I wouldn't run into hot weather that could potentially make a car run hot now did I. But I did say I was going to run a 60 distilled water / 40 antifreeze with.......here comes the drumroll..........WATER WETTER!!! Look up what that is and you should better understand that that mix will far exceed that of a standard 50/50 mix. ;)
Talk about having a stick up your ass... I was simply stating a fact, not in any way trying to be a tough guy like you seem to be... Theoretically, you shouldn't run into a boiling problem if everything is in order, unless of course something goes wrong. You asked for answers and you got them, now you chew people's heads off because apparently you're better than everybody else? Calm yourself Steeda Boy, we're all learning, even YOU ;)
unless you change the thermostat to a lower temp and adjust your fan temps via the tune.. the car is gonna STILL run at 200 degree's.
running a surfactant in the cooling system does give the ability for the engine to run cooler, but it WONT.. unless you change the thermostat AND the tune to reflect this added cooling ability.
Datalog the car, BEFORE you change the coolant and afterwards.
Simply changing the coolant wont have a "significant" impact on the temp, unless you make SIGNIFICANT "hardware and software" changes.
Not trying to chew your head off, but the "Antifreeze also raises the boil temp doesnt it? Not that you should run into that.." comment didn't have to end with a sarcastic indirect shot at me. That insinuated that it will overheat since I live in Florida. I knew what your were pulling with that comment. I had no gripe with you whatsoever, but you took it upon yourself to try and take a discreet, indirect shot at me.
You took another one with your Steeda Boy comment. Don't know where you get off calling me boy, or how old you think I am, but again your immature comments are unnecessary. I love how you can feel like a man name calling behind a keyboard, but whatever makes you feel better.
I never said, nor insinuated I was better than anyone else. Please point out in my post where I insinuated I was better than anyone here? Again making baseless claims.
I've got respect for anyone that respects me. But if anyone disrespects me, plan on getting the same treatment. Plain and simple! I believe in equal justice, and equal treatment..........
Evidently, you DIDN'T know what I was "pulling" with that comment... I told you what I was "pulling" with that comment in my reply, I simply meant that you shouldn't run into overheating problems as long as everything is in working order. There is the off chance of something breaking (it is a car), and you COULD possibly run into an overheating problem, but SHOULDN'T. I "took another one with my Steeda Boy comment" because you spoke down at me for no reason that I could see. This supports the fact that you insinuated that you were better than somebody else. YOU started it. That's where I "get off" calling you "Boy," now I've insulted you and we're even. I too believe every man is created equal, so stop talking down at people. Bury the hatchet
If that's the case, and you're intentions weren't meant how I took it I apologize for my oversight.
Wow... all over antifreeze?
I will say though that Tommy is no internet tough guy, I met him in person and he's crazy :D
Dude get the f'n stick out of your ass! I asked for some help about HOW to change the radiator fluid NOT WHAT TYPE OF FLUID TO USE! AGAIN, your advice about water wetter was noted but do you expect people to drop everything and do exactly as you say?! Seriously dude, I don't care how long you've been on this forum, or how respected you may be, I'm not just going to do as you say! I'll comprehend it, and research it, but I'm not going to take it as textbook fact!
Anyone with any bit of intelligence takes everything they hear, formulate a hypothesis, and go from there. You don't just take every persons word as text! I had a guy that everyone boasted about being the best mechanic on the east coast for stangs. I brought my car to him, he diagnosed it wrong, I figured it out through tips from fellow forum members, and my own problem solving. Point is just because you may be an expert doesn't make you always right.
My mentioning working at Steeda wasn't pounding my chest, nor was it to boast about how knowledgeable I am.
WHICH IS WHY I STARTED THIS F'N THREAD IN THE FIRST PLACE!
My god dude, f'n read what people post before you start getting on your high horse acting like your tough :q:q:q:q.
Something tells me if this was face to face this conversation would be going much different. It always does..........internet is always the place for people to act big. :rolleyes:
it just aint worth it....screw it
I just used that one thing... umm google?
Ya Evans is the waterless stuff... Frogman do you run that in all your stuff or just the diesels?
