ripped camel
Frogman, I searched to about page 10 when after spending 30 minutes looking all I got was that you need to burp it correctly. So search DIDN'T help...
I would like to do a flush and fill with the radiator fluid. All I need to know is if there is any special advice or steps on what to do.
I've done a few cars before but never this one. Is it the usual steps which is...
1. Drain fluid from the bottom of the radiator.
2. Open the radiator cap and continually poor distilled water in while the system is running to ensure everything is out.
3. Shut the car off and let the remainder of the distilled water drain out with the car off.
4. Fill up the radiator tank AND resevoir to required levels.
5. Start car.
6. Continue to fill with correct mixture after thermostat opens.
7. Done
Isn't waiting till the thermostat opens 1 or two times the same thing as burping the system? I only need the radiator cap to be off to burp the system while it runs right?
Thanks.
5. Start car.
7. Done
Thanks.
