the unlock button on my keypad doesnt work. is the code for the door keypad located somewhere in the car? any help guys? everytime i unlock my door the alarm goes off and i have to start the car quick. PITA!~
There's a sticker on the right side trunk hinge
You're welcome, no problem. BTW, nice car. I'm suprised nobodys said it yet,but your wheels are backwards.
the code is also on the keyless entry module, but on 97 and 98 they moved the module from the trunk to behind the driverside door panel. do yourself a favor, go on ebay, or someone here may have one, get a 97 - 98 owners manual, open it up to the alarm section, and program your own 5 digit code into the cars system, it will not erase the factory code, but if you have a 5 digit number that means something to you personally, you can use it also, that way you'll never forget, mine has the factory code plus a 5 digit code means something to our whole family so none of us can ever forget the code. its very simple to do.
uhhhhh enter the code then press 1/2 type in the number and uhhhh i thought theres something after that, might not be, i dont have to on my explorer
I have the instructions for my 93' Would it be same procedure for gen 2? If so, will type it up here...
Ok, here goes, straight from my owner's book:
You can program a personal code to unlock your vehicle. This code does not replace the permanent code that the dealership gave you. Use your personal code in the same manner as you would your original code.
To program your own code:
1. Select five digits for your personal code.
2. Enter the code that the dealership gave you.
3. Within five seconds, press 1/2
4. Within five seconds of pressing 1/2, enter your personal code, pressing each digit within five seconds of the previous digit.
The keyless system registers this second code. To open your vehicle, you can now use either code. The module remembers only one personal code at a time. Entering a second personal code will erase the first, replacing it with the new second one.
To erase your personal code:
1. Enter the original code.
2. Press 1/2 within five seconds of step 1.
3. Wait six seconds.
The keyless entry automatically erases your personal code.
You just saved $8.99 and FREE digital delivery by not going to ebay. haha good job
