Kid_Lyrics
so what your telling us is that your (recently) un-pressurized system is still giving you problems and leaving the car loose did not fix your issue?
No one is surprised of this...
In fact this is what you were told would happen until the car is properly fix AKA replacing all of your worn out plastic cooling parts.
So either get used to not being able to get where you need to go, or replace all of the plastic cooling parts.
Yea yea, You don't need to get snooty with me. I'm not responding to it. I'm just showing what happened. I didn't expect a perfect system nor did I expect a perfect fix. I just needed a way to work. So you can keep your attitude to yourself. Thanks. Not to mention, if you read what I said. I stated that was after driving 40 mins to work and 40 mins back right after each other. That didn't include any stopping. So, I expected it to happen. It wasn't a lot. Hell, it wasn't even enough for 4 cups of liquid. So I wasn't worried. It steamed when I got out and I didn't look back in worry. Why? When it WAS pressurized and I drove to work and drove back before as I did this instance, It exploded when I arrived home. I got home and LITERALLY the second I parked, it exploded. So, In reference to your comment. I pay it no attention. I know I need to replace the parts. I plan on it. I just need to get to work. K? thanks!
Unless you get that fan fixed, it will never be right.You can put up with some boilover,but if I couldn't get the fan fixed and I HAD to drive it to work, I'd put at least a 50/50 mix in there,KidL. How long til you get the fan fixed? don-ohio^)
Yea, I'm shooting for this Friday. Since I don't work all week. I'm planning on heading out to get at least the motor for the fan at this moment. I'm just gonna replace them one a time simply because I don't have the entire amount for the parts. So hopefully in the next two weeks I can replace everything overall.
