oddball
There's an entertaining fight going on that deserves its own thread instead of mucking up everyone's repair/help threads.
Should an auto cooling system run unpressurized? Is it acceptable to run unpressurized, and if so, for how long? It is likely to cause issues, or to fix problems?
The argument for non-pressurized is systems with aging and fragile plastic parts tend to develop very small cracks that expand under heat and pressure, causing leaks and overheating. By running unpressurized, the cracks are less likely to form since the parts aren't under pressure stress, and any existing cracks are less likely to open.
I think the LS V8 does not lend itself to running unpressurized very well.
First, the engine doesn't get very much coolant flow:
1) The cooling path is very complicated, without considering the heater circuits, hindering free fluid flow and exchange with the radiator.
2) The water pump has notoriously low flow rate, hence the need of an Aux pump
This means coolant moves relatively slowly through the engine, which means it will accept more heat. Running unpressurized has a much lower boiling point. Combine poor flow with a lower boiling point, and the engine should experience spot heat and boiling, particularly around the exhaust valve seats. The really bad part of spot boiling is it can create an air pocket that is self-reinforcing. Poor flow means its more difficult to collapse that pocket. Also note that the CHT is on the intake side of the head, which may continue to flow properly while the exhaust is experiencing boiling.
IMO, running unpressurized is more likely to cause long term damage, especially a warped head or block. If the engine is babied then it may survive fine, but elevated exhaust temps would stress this configuration significantly.
I suppose my main question is if a system is overheating when pressurized, how does running non-pressurized resolve the overheat?
