Part list for rebuilding my front suspension
aZLiNCoLNMk8
Mesa
So I put orders in for my parts which should be here sometime this week. I was just wondering if I could get some feedback from anyone who has done this before and to make sure I have everything I will need. So my list looks like this:
SCP.com: Poly Rack and Pinion Bushing Kit, Right Upper Control Arm Assembly, Left Upper Control Arm Assembly, Right Lower Control Arm Assembly, Left Lower Control Arm Assembly, Bushings for Rear of the Front Susp. Strut Rod, Poly Bushings for Front of the Front Susp. Strut Rod, Addco 1 1/4" Front Anti-Sway Bar = $650.92
RockAuto.com: ACDelco Reman. Rack & Pinion, SKF Front Wheel Hubs, Moog Sway Bar End Links, Moog Outer Tie Rods = $597.50
Well I hope I covered everything I need part wise and any feedback is much appreciated. Thanks for your time!
Looks like you have studied the situation, the only thing I would add to your build would be new Brake rotors (Bendix) and Ceramix brake pads from same. This would also mean a brake fluid replacement and I would recommend "Super Blue" as it is easy to see (Blue Color) and is DOT 5.
There will be other opinions showing up here soon.
Did you order the LCA from the same year t-bird to avoid the Lincoln tax?
Thanks much for your reply Roadboss, I will definatly be looking on the Bendix site to see what they got. Just got my order from Rockauto.com today, it's like Christmas all over again! Will be posting pics here soon.
I like rockauto.com and I could have given you a code if you didn't already find it on the site where I have listed it. It would have been an additional 5% off.
This discount code expires on March 21, 2010
26933292228257 <---this goes in the space where it asks "where did you hear about us. Only the code, that's it. Numbers only!
Thanks NoLimit, much appreciated!! I recieved my order earlier today, but I will save this because I will be more than likely ordering from them again. Their delivery was fast and I have no complaints, great service!!
New Hardware
When I recently rebuilt my suspension, I also ordered new bolts and nuts for the UCA and lower shock.
Lower Shock Bolt/Nut:
Part Number: N808998S436 List Price Your Price BOLT&RET M14X2X92 HE $7.29 $4.01
Part Number: N620604S100 List Price Your Price NUT-M14X2.0 HEX LOCK $4.50 $2.48
UCA Joint Bolt/Nut:
Part Number: N806579S428 List Price Your Price BOLT-M12 X 1.75 X 64 $10.00 $5.50
Part Number: N805475S436 List Price Your Price NUT-M12X1.75 HEX LOC $2.75 $1.52
