aZLiNCoLNMk8
So I put orders in for my parts which should be here sometime this week. I was just wondering if I could get some feedback from anyone who has done this before and to make sure I have everything I will need. So my list looks like this:
SCP.com: Poly Rack and Pinion Bushing Kit, Right Upper Control Arm Assembly, Left Upper Control Arm Assembly, Right Lower Control Arm Assembly, Left Lower Control Arm Assembly, Bushings for Rear of the Front Susp. Strut Rod, Poly Bushings for Front of the Front Susp. Strut Rod, Addco 1 1/4" Front Anti-Sway Bar = $650.92
RockAuto.com: ACDelco Reman. Rack & Pinion, SKF Front Wheel Hubs, Moog Sway Bar End Links, Moog Outer Tie Rods = $597.50
Well I hope I covered everything I need part wise and any feedback is much appreciated. Thanks for your time!
