MarkVIII93
Where can I get one?
Has anyone checked with Torrie, Max etc? They all have access to locators...
Yes.i have seen references to the oil pans on these before, do they rust out and leak? when I go my 96, it had rust on the bottom of the pan and I sanded it lightly and sprayed it with engine paint-so far, so good, i don't have any leaks, but is this a common problem in rust states?
Yes.
I removed my oil pan, sanded every bit of rust off, and spray painted it with 3 coats, and baked the paint in. Dupli-color brand black engine enamel is what I used.
It lasted about a year before it started peeling away.
It's supposed to be good up to 500 degrees, but if it wasn't strong enough to stay on an oil pan, I don't see how that stuff can last on top of an engine, where the heat and other conditions are much more harsh.
hrm.....
im pondering yanking that engine at the pick n pull even more now. got a good pan on it....
I'll have to go after it again before the rust gets bad. I'll try the primer next time.its all about the preperation...
