No cold air out of AC
Lincoln LS
  1. perpetualchange
    perpetualchange LVC Member
    43
    Jan 2, 2013
    sewell
    I'm not getting any cold air out of my AC, just hot.
    Can anyone help me diagnosis and eventually repair?
    I tried just giving it a shot of frion but it wouldn't take.
    For reference, I drive a 2004 LS v6.
    Looking forward reading some responses!
  2. kcam67
    kcam67 Active LVC Member
    103
    Apr 12, 2010
    detroit
    Same here and I posted thread a couple of weeks ago and had some pretty insightful advice. I too, noticed that I wasn't getting any cold air coming from my vents with A/C level set to high. First thought was that R134a level was low and checked to see if the clutch was engaging on the compressor. Clutch wasn't spinning so that tells me not enough "juice" and bought a full can of R134a refrigerant refill. I started to fill it on the low side pressure and after about 30 seconds, the clutch started to spin on the compressor and kept an eye on the gauge that came with the can until it was properly filled. Still no cold air so did more research here and found that most folks who have this issue reports that the culprit is most likely your DCCV module, located torwards the front of the vehicle and is attached to the fan shroud. I bought a new DCCV and replaced it but Still not getting cold air. I'm at a loss now.
    BTW: 2006 V8 LSE 75Kmiles
  3. joegr
    joegr Dedicated LVC Member
    19,514
    1,417
    Dec 10, 2005
    Gulfport
    Have you searched/read any of the threads on here?
    Is it heated air, or just not cooled air?
  4. perpetualchange
    43
    Jan 2, 2013
    sewell
    Sounds crappy. How was replacing the DCCV on the v8? On the v6 it looks like it needs to be done by someone with long, skinny arms...
  5. perpetualchange
    43
    Jan 2, 2013
    sewell
    It's pretty damn hot IMO. I had no issues with getting heat in winter.
  6. joegr
    19,514
    1,417
    Dec 10, 2005
    Gulfport
    Probably the DCCV then. It may have blown the fuse too.
  7. RigsLS
    RigsLS Dedicated LVC Member
    7,761
    516
    Mar 10, 2012
    The DATC might be bad as well is another option.
    Has Fuse #1 and RELAY #08 for the A/C clutch been checked ?
    DOES the A/C indicator light turn on when the A/C button is pushed and off when the OFF button is pushed?
    Heater Core Plug Test
    Someone correct me if I'm wrong here but ... (haven't done this myself before so unsure, just read about it.)
    there's three coolant lines going through the firewall into the heater core with hot coolant inside them.
    Top two should be input lines as the DCCV stands for Dual Climate is has separate lines for either side,
    bottom line is the coolant recovery line.
    One could pinch off the lines with vice grips and see if the flow of heat stops, if the AC is working correctly you should get cold air.
    it's essentially the same as what the DCCV would do, open the valves to allow hot coolant to flow through to the interior heater core.
    The DATC module is not able to control the DCCV valves properly as the solenoids inside may be stuck in the open position.
    RECAP:
    - Remove the passenger side cowl cover.
    - Clamp off the three heater hoses going to the heater core, as close to the heater core as possible. (DISCLAIMER: It's not a permanent solution!)
    - Set the DATC module to 60° F.
    Is cooling restored?
    • Like Like x 1
    • kcam67
      103
      Apr 12, 2010
      detroit
      It actually wasn't bad at all. The only thing was that I had to drain most of the coolant fluid. It was very accessible once you remove the air box and all the attachment that comes with it, you are golden. While you are at it, you might as well or think about replacing the serpentine belt. That was a 10 minute job. Believe it or not, the problem I had was deciding wether to do a total coolant flush or just refilling what was drained out of my car when I swapped out the DCCV module.
    • perpetualchange
      43
      Jan 2, 2013
      sewell
    • kcam67
      103
      Apr 12, 2010
      detroit
    • jjcool00
      jjcool00 Dedicated LVC Member
      1,926
      98
      Jun 19, 2012
      Elizabeth
    • joegr
      19,514
      1,417
      Dec 10, 2005
      Gulfport
      Never heard of a "relay fuse."
      There are fuses and there are relays, and sometimes a fuse is used to protect a relay.
      I think you must be talking about a relay, the compressor relay?
    • kcam67
      103
      Apr 12, 2010
      detroit
      Didn't about that one, thanks. I will check it when I get home today. On another note, I did borrow a gauge to properly check the high and low side for refrigerant level, if there is too much refrigerant in the system, would that also be a factor in getting the A/C to work or blow cold air?
    • kcam67
      103
      Apr 12, 2010
      detroit
      Joegr is right, we are getting ahead of ourselves. Fuses are small see through color coded and you can actually see if it is blown but the relay are black in color and cubed shaped solids. You'll see it when you pop the fuse box in the engine compartment underneath the hood.
    • perpetualchange
      43
      Jan 2, 2013
      sewell
      I don't know anything about it.
      My Fuse 1 was definitely blown, though.
    • jjcool00
      1,926
      98
      Jun 19, 2012
      Elizabeth
      Yes, if you overcharge the system you could even burn out the compressor. I've seen this happen personally. What readings did you get?
    • RigsLS
      7,761
      516
      Mar 10, 2012
      re&re your DCCV.
      as I mentioned, you could pinch off the heater core lines to get some relief for the time being and to see if the A/C is actually working.
      also turn on the A/C for a bit and check your refrigerant lines under the hood, they should feel stone cold after it has run at 1500RPM for a bit.
      It would then indicate it's working but the DCCV is not playing nice with it. the DCCV is meant to stop the hot coolant flow across the heater core.
      Fuse 1 protected Relay 08 and I did not call it a "Relay Fuse"!
    • kcam67
      103
      Apr 12, 2010
      detroit
      Haven't measured it yet. I just got the gauge from a friend at work today. Will see if I can check it tomorrow. I'll check back in when I have results. Also, BigRigLS has a good point which I will also test out.
    • perpetualchange
      43
      Jan 2, 2013
      sewell
      I'll try it, thanks. Where would the heater core lines be? Just the hot lines going into the DCCV?
      I'm a newb with DIY car maintenance, if there's some more detailed drawings than what's in the owner manual that'd be helpful. I don't even think I see the DCCV in the owner's manual.
    • joegr
      19,514
      1,417
      Dec 10, 2005
      Gulfport
    • perpetualchange
      43
      Jan 2, 2013
      sewell
      Looking at it now. I'll take some pictures and report back as to what differences I have going in with the v6.
    • perpetualchange
      43
      Jan 2, 2013
      sewell
      Well, no need to replace the valve.
      I started it up, pulled out Relay 8, and plugged Relay 8 back in and, viola, the compressor clicked and cool air started blowing.
      Cooler on one side than the other but cool enough!
      Now onto solving my lamp issues.
    • RigsLS
      7,761
      516
      Mar 10, 2012
      You're not out of the wood just yet, if only it was that easy my friend.
      Relay # 08 clicked open and stayed open and the fuse for it blew, as far as I can make sense of it.
      It will redo it again in a matter of time.
      Your cold on driver-side but warm on passenger-side is a faulty DCCV. It needs to be replaced.
      --- EDIT: could also be related to a faulty inside ambient temp sensor(s) but doubtful.
    • 1LoudLS
      1LoudLS Dedicated LVC Member
      9,901
      350
      Mar 31, 2008
      Ann Arbor
      i wouldn't be too sure of that, because this right here
      is another super common symptom of a failing DCCV.
    • RigsLS
      7,761
      516
      Mar 10, 2012
      //// joke ////
      It's actually an additional feature Lincoln motor company build in to this DCCV, comes as a "graduated" option.
      Driver-side Cold, Passenger-side HOT ~ keeps the driver COOL and his bitch HOT looking!
      [​IMG]
    Share This Page
