New Member Into
Lincoln LS
  1. s-type guy
    s-type guy LVC Member
    10
    6
    Nov 5, 2018
    Greater Chicago Metro
    Ahoy !
    New member here.
    I've recently purchased a Jaguar S-type and am needing advice to sort out some problems on components in-common with the LS and, to become smarter on the commonality. Frankly, I am thinking that LS, Thunderbird and Ford people are more gear-heads and hands-on folks than the Jaguar crowd.
    Hope I can be a good member of the Forum.
    Apologies in advance for any violations of Forum etiquette.
    S-Type Guy
  2. RollinLS
    RollinLS Moderator Staff Member
    4,765
    145
    Jul 4, 2005
    TBA
    Welcome. What are you needs to know?
  3. s-type guy
    10
    6
    Nov 5, 2018
    Hello.
    Thanks.
    Immediate need is to solve a shift lever issue on the 5R55N trans. Have to pull lever full back and apply a little bit of RPM to engage drive.
    Recently purchased the car and am just beginning to go through it. And, have yet to check trans. fluid level. Ugh - have to go to a shop read: level elevation to have fluid level checked. Mind boggling they went through the effort to "de-configure" a dipstick. So, need to find a "friendly" shop in the Chicago Metro area with which I could work.
    Regards.
  4. 112 LS
    112 LS Dedicated LVC Member
    544
    37
    Jun 22, 2004
    NJ
    I'm not sure you can even check the trans fluid on the LS. From what I know it's a totally closed system.
  5. joegr
    joegr Dedicated LVC Member
    19,378
    1,393
    Dec 10, 2005
    Gulfport
    Yes, of course you can check. You have to raise the car up and crawl under it and remove the inner drain plug (provided just for this purpose), but you can check it.
    It's no more closed or open then any other automatic transmission, it just doesn't have a dipstick. It wasn't the first car without one, and there are very many now that don't have one. That doesn't bother me, but the cars that don't have engine oil dipsticks do concern me some.
Share This Page
