Need some 4" cuved intake piping.
LaserSVT
Waco
Figured one of you could point me the right way. I ned one last piece to do my blower install. I need a short section of 4" diameter pipe that is slightly curved. It can be a 90* or 45* and I can cut it to fit but I also need a 4" coupler.
This will connect the Cobra tube to the Lightning MAF meter so I can place it in a stockish position should I be forced to use an open air filter so it can be fed a little cool air. It may also allow me to retain my stock box but not sure yet.
Any ideas? And I am not talking home depot. Their 90* PVC pipe has large flanges on it which would make it too short after I cut them off.
The section I need is the shiney silver part before the MAF meter.
I just realized the Cobra intake tube appears smaller then the Marks tube. Anyone know what the opening size of the 96-98 Cobra tube is?
I am fairly sure the 90mm Lightning MAF meter is 4" but may need a reducer coupler if the pipe is 3.5" or 3"
Good catch.
Yeah, the Lightning MAF is 4" and the 96-98 Cobra intake tube inlet is 3.5".
Well that saves some coin. So I guess I need a 3.5" pipe and a 3.5" to 4" coupler.
Well the place around here dont have what I need so it looks like a place in dallas does though. $23 for the pipe shipped and $18.25 for the coupler shipped.
Freakin blower is nickle and diming me to death. :lol:
go to an exhaust shop that does diesel work...they should have it in stock and be able to bend it how you want it.
tubin'
Try stainless sanitary tubing used in food production facilities- comes in all sizes, can be polished, welded, and bent.
Thanks guys but I found the 3.5" pipe and 3.5" to 4" coupler I need. I will order them tomorrow.
Although for their cost it seems I could find an oval to 4" angled coupler and put in a 4" PVC pipe amd eliminate that restriction too....... :D
Is that 4"? If so I am gonna knock you over when I get down there as I just paid $40 for a freakin 90mm MAF adapter. The pipe wont work though cause the Cobra intake tube is 3.5" and thats that.
