Need help locked my keys in car
Lincoln LS
  1. SoonersLS
    SoonersLS LVC Member
    36
    Oct 16, 2013
    Oklahoma
    HELP LVC So I was cleaning my baby and I accidently locked the keys inside it even worse the car is running. Its sitting on the street right now running with my keys locked in there. Is there a way to get back in? Im gunna go get a coat hanger and see if I can break in brb
  2. Ghost_Ls8
    Ghost_Ls8 Dedicated LVC Member
    1,142
    33
    Aug 19, 2013
    Chicago
    if u do use a hanger , use something rubber to create a gap between the door but have a microfiber handy so u wnt scratch the paint
  3. joegr
    joegr Dedicated LVC Member
    19,658
    1,442
    Dec 10, 2005
    Gulfport
    Well, that didn't take long.
    Enter the factory code or your personal code on the keypad on the door and get in that way.
    Surely, you have more than one key?
    Call a locksmith. It'll cost less than the damage you will do trying to get in.
    Break out a side window, or if the windshield already needs replacement, break it.
    • Like Like x 1
    • Alax7
      Alax7 Dedicated LVC Member
      7,816
      38
      Dec 18, 2008
      LA
      :slam You're on a roll young one.
    • SoonersLS
      36
      Oct 16, 2013
      Oklahoma
      god dammit. dont have another key here and dont no what the door code is. Where is the battery???? is it under the engine? I was able to pry open the hood and in the box up front I dont see any + - connectors.....
    • SoonersLS
      36
      Oct 16, 2013
      Oklahoma
      the car had a full tank of gas in it how long will it run for if i cant turn it off?
    • lincolnelite
      lincolnelite Well-Known LVC Member
      311
      8
      Sep 24, 2013
      Kansas City
      weird, normally the car won't lock itself if the key is still inside (and running)
    • Ghost_Ls8
      1,142
      33
      Aug 19, 2013
      Chicago
      Battery is located in the trunk, best course of action now is call a locksmith or someone that knws how to break into a car
    • qzyl2m
      qzyl2m Active LVC Member
      86
      3
      Oct 19, 2005
      canada
      [Write down your VIN and go immediately to your closest ford dealer for a new key. Take credentials with you
    • joegr
      19,658
      1,442
      Dec 10, 2005
      Gulfport
      The battery is in the trunk. Don't mess with the electrical connections up front, that won't get you in the car. It can get you a major repair bill. Speaking of which, I hope you didn't bend that aluminum hood, because it won't bend back.
    • joegr
      19,658
      1,442
      Dec 10, 2005
      Gulfport
      It most certainly will if you press the 7/8 and 9/0 buttons on the outside of the driver's door at the same time. Also, if you lock the doors manually instead of with the inside button.
    • SoonersLS
      36
      Oct 16, 2013
      Oklahoma
      car is still running LOL. what fuse can I pull to turn it off?
    • Ghost_Ls8
      1,142
      33
      Aug 19, 2013
      Chicago
      would not recommend messing with fuses and your electrical system , jst read something about blocking your exhaust with your shoe,that will stall your engine and not cause damage to it , but seems weird to me to so i wudnt do it , but i would still try to get a hold of a dealer or locksmith
    • joegr
      19,658
      1,442
      Dec 10, 2005
      Gulfport
      Let it run. That won't do any harm. All the other stuff you are thinking of might.
      At this point, break a window or get a locksmith. You're going to have to do one or the other. Stopping the engine won't solve the problem of needing to get into the car.
    • SoonersLS
      36
      Oct 16, 2013
      Oklahoma
      my mom thinks the neighbors are going to call the cops if its out there running all night. how hot can a LS get from running. the needle on the left side it all the way towards the top. Is that the temparature?
    • SoonersLS
      36
      Oct 16, 2013
      Oklahoma
      I think I might have broke something when I pryed open the hood. I used my dads crowbar and jammed it under by the grill and hit the latch and now there is some little rocket thing on a wire that looks like it broke off
    • jmtiseo
      jmtiseo The Peanut Gallery
      2,573
      32
      Jul 10, 2011
      Romeo, MI
      Don't pull the fuse, your car will fall for a banana in the tail pipe.
      filepicker-iDeV6rwSdKBOxAcqaaUQ_tumblr_l2ryjzrAJb1qbs6n7o1_400-2dragged_zpsfcdb5466.jpg
    • Ghost_Ls8
      1,142
      33
      Aug 19, 2013
      Chicago
      Dude never take a crowbar to a cars hood , and u didnt break anything, there is a sensor right under the grille that is held with tabs so when u pryed it with the crowbar u prob knocked it lose, not a big deal but stay away from the hood of the car with that crowbar
    • joegr
      19,658
      1,442
      Dec 10, 2005
      Gulfport
      That's the exterior temperature sensor for the climate control and the heated wiper parks.
    • joegr
      19,658
      1,442
      Dec 10, 2005
      Gulfport
      If the cooling system is working correctly, it can sit there and idle for a few days and never get past the center (normal) mark.
      Would've been cheaper to break a window or call a locksmith.
    • qzyl2m
      86
      3
      Oct 19, 2005
      canada
      Don`t worry thats the fuel gauge. You did say it was full of gas
    • SoonersLS
      36
      Oct 16, 2013
      Oklahoma
      what window would be the best one to break im gonna have to do something soon
    • SoonersLS
      36
      Oct 16, 2013
      Oklahoma
      my friend said if i shove a potato in the muffler it will kill the engine. is this true? will it work better then the rags?
    • joegr
      19,658
      1,442
      Dec 10, 2005
      Gulfport
      Yes, probably. The key will still be on and the battery will drain. This will shorten its life, possibly to the point that it will have to be replaced very soon.
      It still seems to me that if you kill the engine, you will still be locked out of the car, and you will still have to break a window or call a locksmith. I'd go the locksmith route. Otherwise, pick one of the back side windows and break it out. Be careful cleaning up the glass so as not to cut up the seat.
    • mark0101
      mark0101 Dedicated LVC Member
      2,262
      46
      Apr 30, 2005
      Jax, FL
      This IMO is the easiest and cheapest method.
      [video=youtube;M0v6O-sFl_g]http://www.youtube.com/watch?v=M0v6O-sFl_g[/video]
    Share This Page
