jmtiseo
The Peanut Gallery
Well I've been real busy with work but I'm going to squeeze a thread in here about my upcoming sub build. It took me about a good two weeks of planning the box but I figured since I got it finalized I can start a thread.
Just going to say this is not going to be too extensive like other sub builds on here, especially the one where he goes through the "big 3 upgrade". Just wanting to share what I'm doing. This isn't a compare and contrast session. There's many different subwoofers, amps, and people out there. I've been pleased with the Image Dynamic brand, and my brother's been pleased with the Kicker Amplifiers.
Current System:
This thing pounds but I'm looking to gain a little clarity, an update, and just a wee bit of trunk space. This system has been with me since I was about 17, now 22. My brother had it a couple years before I did so I'll call her ol' reliable.
Up Next:
Subwoofer Enclosure Plan:
As I mentioned before it took me about two weeks to come up with the plan for this box. I ran it through WinISD (An enclosure design software) and Torre's Box Tuning Calculator found through this forum. With the design below WinISD, with the sub's specifications, says my box will be tuned to 30 hz, with a vent mach of .05. From what I've read, port noise (chuffing) becomes audible at a vent mach around .1. This is caused by turbulence within the port, and is why I am rounding the edges of my port to help prevent any.
This is all from, in my opinion, mind boggling research. It's much easier to throw a subwoofer into a sealed box but I like the challenge of doing a ported enclosure. I could have saved a shitton of space doing a sealed enclosure but each type, ported and sealed has their advantages as well as disadvantages. I believe I've done enough homework thus far to go with a ported design that is shown below. It's not the most detailed print but it does the job.
Some concerns:
Looking to start next weekend over the holidays.
Current System:
- Two Image Dynamic's iD 12's
- Kole Audio QX-1920 Class AB Amplifier (Can't find a spec sheet anywhere for this but it's been working mighty fine)
- Polk Audio Door Speakers, stock center channel, and rear deck lid woofers.
- 2.0 cu. ft. net ported box (30.5"x13.5"x24"), 3/4" MDF, tuned an estimated 32-36hz (Need to measure my ports to clarify)
- Stock Head Unit/Radio/Reciever
Up Next:
- One Image Dynamic iDMax 12
- Kicker ZX1000.1 Class D Amplifier
- Infinity Reference Door Speakers, and still rockin' the stock center channel and rear deck lid woofers.
- 2.7 cu. ft. net ported box (30.5"x13.5"x17.75"), 3/4" MDF, 2 4"x24.5" ports (pvc pipe) with rounded edges tuned to 30 hz. See print below.
- Stock Head Unit but looking to upgrade to Pioneer AVH-P4300DVD within the next 6 months.
Some concerns:
- Of course the abuse on my electrical system asking for 1000 watts of RMS.
- Porting a box decreases the power handling of the driver (so I've read) and may damage the subwoofer. For this reason I'm going to start by wiring it to 4ohm and 500w RMS to see how she handles and break her in. If I like this result I may just leave it hear knowing that I should be able to run it like that all day long and it's a lot less strain on my electrical system than my current one.]
- Clarity, I'm running this off of a line out converter until I get said double din.
- Port Noise (Chuffing)
- Miscalculation causing my box to be tuned to high or too low.
- My woofer grilles will not be tall enough for the excursion of the iDMax. I like the look of these and they're discontinued Kicker G12 Subwoofer Grilles. It's unfortunate that one of them snapped because a friend of mine broke it while helping me lift it.
