zmt325
the car is a 95 with a bad engine, kooks, sct chip, under drives, 900 maf, cold air box, bbk fpr, and a few other things gears, Auburn locker, 255 walbro ect ect. it may have some cams. i got it to run and I could almost swear it was loping. (and well.... knocking) the p.o. was well... frustrated with it. he actually said "good riddance you fuggin b!tch" just before we left. i will get into that more as the build progresses.
picked it up for $650 solid car black on black base, no roof,no rust and 200k on car .
i have purchased a 96-98 cobra upper and lower with the rail, throttle cable, cruise cable, brackets for throttle + cruise cables, throttle body, 5/16 fuel line and some fuel line connectors.
the reason for the cobra intake, once i finish this part of the project, i want a vortec or procharger within the next year. then use the original block for a forged build and turn up the boost within the next year or 2.
next week i am picking up a totaled 1998 mark with 80k, p.o. is keeping the trans
but it will have the cop stuff and plastic imrcs and everything else under the hood
I am wanting to do a cobra intake conversion, cop conversion, egr delete, with a second gen motor in a 1st gen car, all at once.
. now that is a rubix cube to me.
I know am in over my head, but i have been here before, things turned out ok last time. i have another mark to drive while i build this one. i want this stage of the build to be a 3 mo max project and i need help.
i have read through each one of the links on this thread like 3 or 4 times
http://www.lincolnvscadillac.com/showthread.php?t=45118
I have not found a good thread on the cop conversion yet, i have been busy at work, haven't had the time to do a proper search. will be reading up on it this weekend.
any one with any advice on how to make the imrcs work, what electrical connectors i need, what cars i can find them on and how in the hell to wire it all up would be much appreciated.
i do have a spare harness to chop on for the swap plus the obd2 harness from the parts car.
should be one bad ass lil girl when i am done...
the project should start in about a mo. i have a few bugs to squash in my 93 so it can become a problem free minty dd
