Alexbougie
that my new dash
So, how did you mask the indicator lights on the climate control and what color/type/brand paint did you use?
Looks very nice!!!
I use dupli-color Ford Sliver frost, for indicator light on climate controlI paint over and after I remove paint for it with an Exacto
Im not sure if he removed them but since they are raised and have the gap its actually rather easy to tape it and stick the blade in and make the cut.
Why waste alot of time and effort to tape off all the buttons when they are easily removed, and as for the indicators it makes no sense to paint over them only to have to scratch the paint back off. The indicators are clear plastic lenses(not LED's) that are easily pushed out.
OK, I got the indicators removed. What did you use to remove the buttons? I tried with a jeweler's screwdriver and the blade is too fat.
Here's some pic's of the buttons & screwdriver's:
The main thing is to take your time! Do not push the screwdrivers in with alot of force as you will shear off the plastic tab. Slide them in easy and twist slightly to pop the outer button off the tab.
