98lincmk7lsc
Nevermind guys, all have been sold...
DLF can you supply these with ES bushings? i would like a set when you have them ready. thanks ken
I could, but if I supplied them with the ES bushings and the 1/8" SS washers, then the price would be even higher, and I'd still need to make a dozen pairs, or so. I don't have access to a cheap machine shop like 98lincmk7lsc does.
I would have them made with a larger 7/8" diameter center hole, however.
The cost of the parts and materials would exceed $50 (the pair of blank plates alone is over $30), and I'd still have to do some machining and welding.
I'm not sure there's a market for a $79.95 shock mount kit.
I don't know if you understand...I'm the one that made DLF's...He just welded in his own bolts.
Once I get some lessons on the lathe at work, I may be able to make up the 1/8" washers also. We'll see how that works....
Well, if you can get some more plates made (with a .875" center hole this time), for less than $20/pr., that would be sweet.
The distance of the mounting bolts to the center hole should also be adjusted slightly. Should be 1.6" instead of the 1.625" in the drawings. The distance between the two mounting bolts on the stock mounts is precisely 3.2".
If you do....
1.25" diameter disc, 12mm center hole.
