low speed vibration
96 shaker
louisville
I have a 96 mark vlll with 135k, had a vibration above 70mph, installed driveshaft out of 93.soon as I started driving it, I now have a vibration that starts at39mph and stays pretty much constant to above 70. I also installed new ujoints w/h ds. Help!!!! 96 shaker
It would almost have to be with a vibration at that low of a speed. If it came from a JY, the car could have been picked up by a forklift and bent the shaft or something of the sort. I think I would swap back because unless you have a whole lot of extra power, it's really not doing any good to have the 93 shaft.
Thanks,I'll try to have it balanced, if that don't work, I'll get one of the high dollar ds.
Try re-indexing the drive shaft while its in there. Remove bolts, turn the shaft 1/4 turn (but not the differential) and replace bolts, test
When i put my 93 shaft in my 97
I had it balanced first and it was a good thing
They said i probably would have felt a vibration at highway speed.
Also look at your tires and wheels
Could be bent wheel, tire ply separation.
B I G thanks to Sapperfire, re-indexing got 95% of vibration out,might go back a play a little more but I can live with now.
