Lincoln LS Lighting Chart
  • Thread starter Thread starter HighRule
  • Start date Start date
H
HighRule
Guest
I'm not sure if this has already been posted but, seeing all the talk about lights made me think a chart might help a little. Also, I'm just throwing this out there. I didn't put this chart together. I'm just sharing trying to make it a little easier. If you see something wrong please feel free to make the correct changes. I was thinking all the lights would be the same but, I noticed some changes in the chart.
-2000 Lincoln LS Light Bulb Chart-
Low Beam Headlight Bulb Size: 9006
High Beam Headlight Bulb Size: 9005
Parking Light Bulb Size: 3157LL
Front Turn Signal Light Bulb Size: 3157LL
Rear Turn Signal Light Bulb Size: 3156LL
Tail Light Bulb Size: 3157LL
Stop Light Bulb Size: 3157LL
High Mount Stop Light Bulb Size: 3156LL
Fog/Driving Light Bulb Size: 9145
License Plate Light Bulb Size: 2825
Back Up Light Bulb Size: 3157LL
Front Side Marker Light Bulb Size: 168
Rear Side Marker Light Bulb Size: 161
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 212-2
Dome Light Bulb Size: 212-2
Step/Courtesy Light Bulb Size: 194
Trunk/Cargo Area Light Bulb Size: 212-2
-2001 Lincoln LS Light Bulb Chart-
-2002 Lincoln LS Light Bulb Chart-
Low Beam Headlamp Light Bulb Size: 9006
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 3157NALL
Front Turn Signal Light Bulb Size: 3157NALL
Front Sidemarker Light Bulb Size: 168
Rear Sidemarker Light Bulb Size: 161
Map Light Bulb Size: 168
Dome Light Bulb Size: 168
Trunk/Cargo Area Light Bulb Size: 212-2 or 912
-2003 Lincoln LS Light Bulb Chart-
Low Beam Headlight Bulb Size: H11
Parking Light Bulb Size: 3357LL
Front Turn Signal Light Bulb Size: 3357LL
High Mount Stop Light Bulb Size: 2723 or 3156LL
Front Side Marker Light Bulb Size: 2825
-2004 Lincoln LS Light Bulb Chart-
Parking Light Bulb Size: 3457ALL
Front Turn Signal Light Bulb Size: 3457ALL
Rear Turn Signal Light Bulb Size: 3157LL
-2005 Lincoln LS Light Bulb Chart-
Rear Turn Signal Light Bulb Size: 3157NALL
-2006 Lincoln LS Light Bulb Chart-
High Mount Stop Light Bulb Size: Assembly
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Maybe if someone wanted to condense the list into all the different unique bulb part #'s and then give some LED Cross Reference that would be cool too` ```
Someone verify,
9145 bulbs and H10 bulbs are interchangeable/sold as the same.
Also, the HID bulbs are D2R can be replaced with D2C or D2S Bulbs. Look online for a quality bulb, the ones from Autozone/O'Reilly's/Advanced Auto are fine but they're $100 each.
Pretty sure that isn't a correct chart.
2006/LSEs have H11 for fogs. And also no gen II has H11 for low beam.
Someone verify,
9145's are interchangeable with h10's or sold as h10's from what I read.
Also, the HID bulbs are D2R and I think can be replaced with D2C's but not D2S's.
Correct about 9145 and h10. Same thing basically. My fogs are h10
Someone verify,
Also, the HID bulbs are D2R and can be replaced with D2C's but not D2S's. Look online for a quality bulb, the ones from Autozone/O'Reilly's/Advanced Auto are fine but they're $100 each.
Same bulb.
D2S are designed for HID-designed projector lamps.
D2R are designed for HID-designed reflector lamps.
D2R has a shield on to help out with the aim - where it's needed.
EDIT: I bought mine from here Amazon.com: Genuine PHILIPS D2R Xenon HID Bulb 85126 OEM Headlight 35W (2 piece): Automotive
I believe I might be running H11 in my low beams.....walks out to the car to check....
Edit: I am running H11 as Lows and 9005 as Highs. Andrizzle could still be right though.
Okay I think I wrote that too soon after waking up.
For some reason I was reading it as H11 for hi beams. Total fail on my part. Many sites list the hi-beam as H11 - so that is where my thinking was going.
But the fogs part I know is H11 for LSE/06.
Some of the fogs are H8's. I know mine aresince converting to the gen II lse bumper.
They sould still be H11s
The Sylvania guide isn't always correct. They have the wrong fog bulb listed for the 06s.
Mine are h8 as well. I'm guessing they switched over to h8 from newer cars using the same or similars forgs as the lse bumper needs, who knows.
the chart was very informative but I was also looking for the dashboard lights and the instrument panel.I was hoping to change the whole color scheme of the interior of my car,but I need to know the light sizes.if anybody can help it would be much appreciated.Thanks
ILL VENONOM
ILL VENONOM
The blubs are clear (white). The coloring is on the overlay.
