It all works! In a nut shell. Here is what I have learned:
1) Thought the calipers were iron, nice surprise there
2) I hate those stupid rotor retainer clips!!!
3) They are not squeal tabs, they were anti-rattle clips, oops
But since no one cares about that, here's the deal on it all...
You will need the following parts:
- Brake Caliper Bracket from an 03-05 Jag S-Type "Sport"
- Brake Rotor for an 03-05 Jag S-Type "Sport" (320mm if not denoted)
- Brake Pads for an 03-05 Jag S-Type "Sport" (Not the exact same as regular LS, but the LS pads might work fine)
- OEM Rattle Clips from Jaguar (HAH!) or modify the stock ones
- 17" Rims or bigger I think (Someone with 16's let me know if it fits)
Here is what I ordered from rockauto to get the job done:
x1 - A1-Cardone 141650
x1 - A1-Cardone 141651
x2 - Centric 12061077
x1 - Centric 10610650
Total: $234 shipped
The caliper is the same. The difference is made up in the bracket. Where the bracket is machined for clearance for the rotor is different by about a 1/4" or so. The bolt hole locations are also different around 1/4" or so. Took me a good few minutes staring at the two brackets side by side to even find the difference. Really is something that can only be measured for sure.
The new calipers have about 1/2" of unused rotor face down near the hub now. The old ones had about 1/4" or so. Again this is eyeball measurement but there is a noticeable difference in placement of pad on old vs new so you are getting the benefit of the bigger rotor via mechanical leverage. Pad is still about 1/8" away from the rotor edge.
The pads have a slightly different curve to them to match the rotor. Despite what centric said, my pads did not have a directional chamfer and instead had a universal chamfer (it's on both side instead of just 1). There were not many options for the S-Type "Sport" in the pad department so I just went with some decent semi-metallic until I new it would work for sure. Now the quest for low-dust ceramics may begin. I dream of the say when my silver wheels still look silver after a week!
The clips on top of the pad will have to be moved out to the very end of the pad. This is to prevent them from contacting the rotor at the corner when compressed by the caliper. The U-Shaped clips will have to have the lip curled up more to match the thinner bracket. I did this by using tin snips, cutting about 1/8" up the inside of the clip, and then rolling it back with a hammer. If you don't do this, the clips will rub.
I have not completed a bed-in yet but once I put 50-100 miles or so on the new pads I will let you know how the brakes feel. Initial impression is more grab with less pedal, and more of a responsive feel. Definitely a noticable improvement but somewhat lacking for me. It still feels like I will need the stainless lines to really get the feel I want though. Not like that's a problem it's on the list of things to do anyways.
Rotor:
Rotor w/ Pads:
Here's how the pads fit the rotors, notice the increased face at the bottom:
A bracket, right side I believe:
Old rotor in new rotor box, showing the diameter difference:
How the bracket is different:
Total: $234 shipped
Rotor:
Rotor w/ Pads:
