RigsLS
- Joined
- Mar 10, 2012
- Messages
- 7,734
- Reaction score
- 523
... check your springs when you get back to work. :shifty:![]()
Airbags, not leaf spring suspension.
Heh heh... I'm just getting it put back like it was although I am going to fork over some of my own money to get a few other paint spots fixed seeing as it'll be in the shop anway.
Forgot to add, any leaf spring can do this so anyone here with a leaf sprung truck, it would be worthwhile to give the 'ol leafs a once over on a regular basis. You don't want to be that guy.
Tractors and Trailers both have yellow tags on them with date codes punched out of them, they are called anual inspection stickers and we are required to verify they are present and that they are within their dates, if they are past their due dates, they are not to be used and either the tractor or the trailers are to be reported out of service.
Large fines for riding around with equipment with past due anual inspection stickers.
Hope everthing and everyone involved turns out ok in the long run.
I was send to our head office today after work to bring mine up which is due for a grease and lube, plus some small things related to A/C and heat, fuse panel cover keeps popping open and a new drivers seat belt plus a marker light out and a fog/drive light out.
I was to bring a loaner back which was an older Kenworth 900 and it needed a good going over in the near dark from me before I put it in gear. had no turn signals for a bit until I worked the signal lever back and forth for 15min. ran like a trooper on the way home though but was sloppy handeling. yet intermediate steering shaft play was within tolerance.
@Rollin;
still going strong here, loading 14K tomorrow for east coast, they may look on the boards for more to fill it with,
spread is into second week of next month.
Update, everything is approved and parts have been ordered. Just had to get the insurance company to approve blending the hood, for some reason the initial appraiser said that the hood didn't need blending when they are replacing a fender. Don't get that. Anyway, once the parts come in they'll get to work.
