Blenderhead
I just got my MarkVIII dyno tuned. The only mods are a 5-speed swap, cobra intake, and straight pipes in place of the stock mufflers. It put down 252hp and 263ft-lbs, which I thought was pretty good based off what I'm seeing from other mostly stock MarkVIIIs. What is confusing me though is where it made peak hp, it was only about 5000rpms! Shouldn't this motor make peak hp a lot higher than that? The hp curve stayed pretty flat from 5K all the way up to 7K when they shut it down, but was slowly dropping off after 5K. What rpm do MarkVIIIs typically have peak hp around?
