the1andonlyGR81
steves not doing j-mods anymore at all, anybody else, or should i go to tranny place and ask?
i thought scp was garbage?
So Bill at SCP is taking the business world like the Bill at Microsoft?
Using other's products and marketing them successfully?
Bill = Bill
I get it!
I know where Hollywood is (my aunt lives near you), but I'm kind of far away near Gainesville. Since I'm guessing you would like someone to do this for you, I've done them before and maybe I can get down there to help you out!
i am always looking 4 help, motor is being done now.those valvebody seperator kits are the same thing as j mod,just swap plates? seems simple.
My 9 year old son could do a j-mod. He set with me while I done one on a 98 and even put in about 10 bolts for me. I let him help me de-burr the holes I drilled. It's simple to do and cost $10 or less. The two gaskets needed are only about $3 each + shipping. 2 drill bits are needed and the plate can be drilled within 3 min and you're done, after removing the steel burr from the holes. Put the valve body back together and it's a done deal. Just don't lose the check balls and if the 1-2 accumulator hasn't been updated, do that too. No need for new springs if neither are broken.
There you go the1andonlygr81! You can get your j-mod done for a Snicker's bar and a glass of Kool-Aid as long as it's after school!![]()
love kook aid, have a big bag of snickers, coming? now with stock it should be worth noting i have a sniper programmerhave changed my shift firmness and raised points, it hits second hard enough to chirp second now with stock rear.i think it works by increasing pressure in tranny lines, but i eas told with j mod it moves more fluid and keeps cooler, with programmer it should really move into second.anybody have both? or jmod with chip?
I have the JMOD with minimal line pressure in the tune. Watch those pressure increases or get opinions from a reputable tuner. You do not want to try to outflow the separator plate with high line pressure whether you have a JMODDed separator plate or stock separator plate or hard parts in the tranny will start to suffer. Your car will shift just nasty(the good type of nasty lol) regardless. Just my two cents and good luck! Have fun with it.![]()
thank you my friend. used to live out there had a friend in snowmass, went for a ski trip to see her in dec 97 ended staying till summer 99. lots of construction out there, especially if you can read prints and know what your doing, actually landed a job that paid for a 3 day a week pass used to ski down to lift at lunch(all the houses were on slopes) ride up and ski back.
by the way you were right about hp. i had wrong sheet an was going off total estimates.never found the one i had, talked to john at shop. he gave me the last run on comp i told him he made me look like an ass will have new one soon.
ok dumb question.with the valve body removed, and gaskets off, why even remove the check balls (i can easily take a pic to remember where they go), if your working above that surface just replacing plates? and the guy i talked to says i dont have to drill holes its done, yet their instructions say to?
http://tccoa.com/articles/tranny/shiftybusiness.html
it doesnt seem difficult, just contrary to what i was told. the one from bill (scp) is the same.
Mine shifts nasty under WOT with both springs in the 1-2. I am beginning to wonder if the spring is broken? :shifty:
