Alexbougie
look at this that need a little of customising but will be great on a LS http://eurotoysltd.com/catalog/product_info.php?products_id=1273&osCsid=53d3c8bc0e1275717d6bb73097343421
Jaguar 4.0L Twin-Screw Supercharger Upgrade (Stage 1)
[4.0TScrw1] $5,995.95
Jaguar 4.0L Twin-Screw Supercharger Upgrade (Stage 1). Eurotoys has developed a major power adder for the 4.0L Jaguar XJR & XKR. This performance package will replace your Eaton M112 supercharger with a High Performance Eurotoys/Kenne Bell 2.1L "Big Bore" supercharger.
The factory Jaguar/Eaton supercharger is not efficient, even at stock boost levels. We can add more power & torque just by installing our Lower Pulley kits, but we know that the Eaton supercharger has its limits. The Twin-screw supercharger is more efficient at higher boost levels, so you will have a much colder air charge. Couple that cooler air with less parasitic loss and you will see a big power increase on a Twin-screw equipped Jaguar (100-200hp + over an Eaton*)! Final power output will depend on boost level, other modifications and engine condition. If you have any questions about this, please give us a call, or send us an email.
When the Eurotoys/KenneBell Twin-screw is compared to other superchargers with the same pulley size, expect big boost and HP gains. The KB 2.1L BIG BORE offers higher air flow with the same rotor speed, so it produces more boost and HP at any rpm. The twin-screw blower takes less power to turn than the factory Eaton, less parasitic loss = even more power!
This Eurotoys/Kenne Bell 2.1L supercharger kit has many components, professional installation recommended. Some parts will require "light" machine work that can be done by hand, while other parts will require extensive machine work to achieve optimum airflow. All of this machining is FREE of charge if you send these parts to us. You will be notified when to send these parts, so that we minimize down-time of the vehicle.
**Vehicle/engine condition needs to be perfect when adding this much power, or serious engine damage can occur! Having low compression, dirty MAF sensors, Check Engine Lights, poor fuel, etc will not be allowed. Eurotoys Ltd. will not be liable for improper installation, or improper use. Premium Fuel is required (91+ Octane in US).
**Every kit is built to order, please allow 3-4 weeks for build time. We have a large wait list right now, if your kit will take longer than the above time, you will be notified and updated on your status.
**Blower is shown with a polished drive, that will only be available while supplies last. In the future the supercharger and drive will only be available in Black.
**If you are currently running a Eurotoys Lower Pulley kit, please notify us when ordering for details on our "Loyal Customer Exchange Program". This kit will be made to work with almost all lower pulleys, please let us know what lower pulley you have. If you have an aftermarket lower pulley, let us know the Diameter!
**This supercharger will have more supercharger whine than your Eaton unit, this is a normal characteristic of Twin-Screw Blowers. if that whine is objectionable to you, then this upgrade is not for you.
Eurotoys/KB Supercharger Kit Includes (all New parts, of course);
-Modified KB 2.1L Big Bore Supercharger & Drive (From KenneBell)
-Eurotoys Mounting brackets & Hardware
-1 Upper Supercharger Pulley
-KB Supercharger Pulley Tool
-Supercharger Bypass Silicone hoses (Black)
-Upgraded Fuel System components
-All required gaskets
-All required machine work
-New Intake Manifold
-New Throttle Body
-New Supercharger Bypass Valve
-Technical support
-Instructions
Eurotoys Ltd. warrants that its products are free from defects in material and workmanship for a period of 1 year from date of purchase. This warranty is limited to repair or replacement of the products supplied by Eurotoys Ltd. which at our sole discretion are found to be defective upon return, freight prepaid, to Eurotoys Ltd. If you have any questions on this, please contact us for all warranty conditions.
(*)Factory horsepower for the 4.0L S/C is rated at 370 DIN, most average 355-365 SAE hp at the flywheel. This can be raised to 450-480hp with our bolt-on upgrades. Anything over that will require the T/S supercharger to support the high boost/power levels. Depending on final power output, other drivetrain modifications may be required.
