tireman
Check this
Your IAC valve on the throttle body could be starting to fail due to carbon buildup. Its a small silver solenoid device that regulates the idle. If it stops working you will get the same results as you did. It varies and is not sequential, it will work for a while then stop. And you will stop too! Take it off, only two easy bolts, clean it out real good with carb cleaner. See if this changes things, else just replace it. Mine went out at about 70K miles. Damn frustrating, engine would start then stop then run then stop.
