Andrizzle
Just thought I'd pass this on since there was many recent threads regarding lights. It says select items, but they have said basically everything in stock will be half off. Now get those LSes updated lights!
Yea I am with you on that, if those go half off, it is pretty much worth a shot @ a pair. I think the old ones had enough complaints of the same flickering we had.
Interiors:
1 2 HID WHITE 6 LED LIGHT BULBS 194 158 168 LARGE
4 2 HID 5K WHITE SMT 5 LED LIGHT BULBS 194 168 158 2821
1 HID 5K WHITE HIGH POWER 3 LED FESTOON DOME BULB 211 212 6413 6429 578
Exterior:
1 V-LEDS HID WHITE 19 M-SMT 8W HIGH POWER BULBS 917 918 920 921 922 923 (license plate)
1 V-LEDS RED 92 M-SMT TAIL/BRAKE LIGHT BULBS 3157 3156 4057 (Tails)
2 V-LEDS AMBER 60 M-SMT PARK/TURN BULBS 3157 3156 4057 (Signals)
1 V-LEDS HID 6K WHITE 28 LED 2X BRIGHTER OUTPUT FOG BULBS H11 (Fogs)
2 WHITE MSMT 6 LED DOME LIGHT 3022 3021 DE3175 6428 6430 (Puddles)[/B]
I will do Rod one better....
Plates:
http://www.v-leds.com/Exterior-LED-...te-LED/5K-WHITE-15W-3-CHIP-HIGH-p9679681.html
Will these work for the plates? Cheaper and look to be whiter at 6k instead of 5k... maybe slightly blueish. Do you think they'll fit? The others are out of stock.
http://www.v-leds.com/6K-WHITE-HIGH-POWER-LICENSE-p4481133.html
LED lights is so expensive, I get the HIDs
The leds are worth every penny by color matching everything it looks amazing![]()
You can still order them out of stock...theyll just ship later but if you wait itll be a bit more expensive and you would still get them later.
I ordered the reverse, plate, and puddle lights as the rest look fine to me for now. These are the most important ones.
If i do led in the interior i may go with warm white....yellow is better for seeing inside than white.
Yes but they will stay on very dim for about 30 minutes unless you add a resistor.
Not enough to drain a battery though.
