Car has been sitting for awhille (4 years whille I was on vacation), went to start it, fired right up, than noticed spewing trany fluid out of cooling line to radiator. Fixed that. Went to start her back up, coolant was spewing out of the thermostat housing (cracked housing) (fine ford engineering). Fixed that. Went to start her up again, no start, engine kept turning but still no start. Fist hits her, she calls AAA on me, Daddy picks her up on his flatbed, takes her home to the stealership. 8hours of non communicating diagnostic equipment she calls me with ransome of 800$. Her daddy bypasses bad wires in harness that controlled the fuel pump. They let me take her for 510$.(prob felt bad for me) Went to start her, fired right up, went to drive out of parking lot she was stumbling and running like $hit. Threw it into reverse n gave the keys back. They had to do the wires for the MAF as well.***
Now she runs good, but I have a data distance error message, speedo dosnt work and odo shows all ------, instead of 71,143. I thought it might have been the VSS, so i replaced it, and still the same. Not to leave out that she has been shifting into second gear too soon. I really could use some help with this, because the TNT is next! Thanks again, Steve.
