So I want to do a tune up. I'm going to start with plugs, and coil packs. What else do I need to do/replace. Also which coil packs should I go with?.
Thanks in advance..
Your wasting you money on coils. unless you have a problem with them, leave them.
I would do everything above but add:
Autolite 764 plugs gapped to .054
MSD\Ford Racing Wires
Trans flush\new filter
Add auxiliary trans cooler
Oreilly has Mobil-1 on sale for $3.40 a quart
CRC MAF air flow cleaner comes in a red can. I didn't look for that in Wal-Mart but I know AutoZone has it for sure.
grey can.
its good stuff. and i believe my walmart carries it.
Did they change it or am I thinking of another CRC spray? Maybe electronics spray is in the red can. As long as it leaves no residue, that's what matters.
Side note: Me and a buddy swapped out my strut rod bushings and then had it aligned today...huge improvment when I hit the brakes (it was ALL OVER THE PLACE when braking)
I had the trans flushed and a new filter done already. I also changed the fuel filter. And I put on new front rotors and calipers. Being winter I'm going to wait to do the trans cooler for now.
I have done alot of this kind of maintaince before but some of it is new to me.
So I don't need to do the coil packs... next weeks plan of attack:
MSD\Ford Racing Wires: Question: My car has coil packs, are there plug wires also?
Clean the maf w/ maf cleaner: Question: do I pull the MAF to clean it?.
Fresh rear diff fluid change
Power steering fluid change
Thanks for all the advice, tips, and help everybody....John
Interesting.From watching one of those automotive shows ... it was warned that Wal-Mart uses the rejected oil from companies. The stuff that they were not going to put out to the automotive stores. (How Wal-Mart get to lower their prices) So be careful ... this is just an FYI not a 100% fact ... I just try to avoid wal-mart for my car. Not worth the extra 1 to 2 $ you save.
Ok, I think got a lot accomplished this weeked.
Plugs and boots, oil change (Mobil 1), air filter, power steering fluid change, MAF cleaned (gray can), had the diff fluid changed, changed the vacume lines from the PVC valve (cracked), checked belts and hoses, washed and waxed, lexol'd the interior, and a new stereo and speakers put in.
Next up - find and fix the oil leak (not bad but a few drops everyday), new upper ball joint on pass side. Look for some seat skirts (mine are beat up, and pulled away from the seat.) Long term - save for paint, accuair air ride system. Love my Lincoln!!!!
whats the proceedure in changing the rear diff fliud? and what kind is best to use?
