Whats involved in swaping hubs. I hear people swap to cobra hubs? Does the cobra hub have the same mounting points as the stock hub assemb. does? first of all, whats the atvantage of runnin diffrent hubs, being able to run diffrent rims?
JC1994 said:A larger wheel selection is the only benefit.
yep, you sure would.MrWilson said:i fancy the 03 cobra rims myself...so id needta do the swap if i were to get them, hua?
evillally said:Front: You need 2 hubs, 2 hub retainers. You break the old retainer, slide the hubs off, slide the new ones on, torque to 220 ft./lbs., new rotors, done.
Rear: You need 2 hubs, 2 bearings, 2 hub retainers, 2 c-clip retainers. Mark the bushing positions, remove the hub retainer, remove three knucle bolts, use a jaw-puller to remove the knuckle, remove the rear c-clip retainer, use a hydraulic press to press the hubs outward, hydraulically press the hub bearning inward, press new bearnings and hubs, new c-clip, slide the assembly on, torque bolts, torque hub retainer to 200 ft./lbs. Re-drill rear rotors or make adapter to relocate the caliper if using 11.65 rotors. As you can tell, the rear section is a PITFA.
The hubs are 5x114.3mm. The Mark VIII and Cobra rotors are the same offset/ tickness- just a different bolt pattern. The rear rotors is where they differ; so you'll either have to re-drill the Mark VIII rotors to the 5x4.25 pattern, or make an adapter per the TCCoA article to run 11.65 rotors.
More rims, bigger brakes, better looking, harder stopping.
lscmkviii said:220 ft/lbs? Thats alot!?
Hey dertyclown where have you been?dertyclown said:not really but rember neaver use an impact on that
lscmkviii said:Do I need a special tool to pull the old hub off?
evillally said:Front; no. Rear; a puller is needed.
