Hi All ! ?
KC96LSC
Kansas City
First of all, hello to everyone. I'm Bbbaaaaaccckkkkk. Hopefuuly from now on. Had one hell of a winter, but I think my Dr's have finally figured out how to make me funtional. Anyway, I was down all winter, the car sat the whole time. I did go out about once a month to start it, but that was about it. Well, I'm still having a little issue. I was having a problem with the car not maintaining it's temp. I put a new water pump an stat in, also it has been filled and burped properly. the fan kicks in at M [NORMAL] and shuts back off at the lower part of M. With that said. The temp usually sets between M and A but once I have to go up a long up hill stretch it heats up to the top of M. Bottom line, it will NOT maintain a steady temp. Any insight would be great.
To all you KC guys, when's the next get together? Anyone going to the Noland road show?
BTW, welcome back. Glad you are doing better. You have been talked about and wished well among friends here.
Welcome back! Check out the thermostat next, that's what I would do.
Hey Dan, I should have mentioned. I have replaced the Stat, Water Pump and Radiator. I'm wondering if there is a heat censor that I don't know about, that might be causing it fluctuate or something else that regulates the temp. Once the temp gets to the top of the M my fan comes on and it keeps it from getting much past that point. Then it seams to come back to just between the M and A which is where it should normally be.
Thanks LaserSVT, I appreciate the kind words. To answer your question, NO. I haven't done anything new to it in a long time.
