I had to do some traveling for work and ended up leaving my perfectly running LSC under a cover in my driveway for a few months. When I returned and went for my first drive I was greeted with an ABS light and Check Traction Control warning message. I could hear and feel the ABS pump working. I checked all the lines and everything seems intact. The weather has been very humid and rainy - do you think I may be dealing with some corrosion and need to clean the sensors? If so, can I just remove the wheel and test the leads of the sensor with my multimeter to find the culprit? I’m assuming its one of the front wheels since my speedo is still working. Thanks for the help! I’m a bit paranoid because I know these sensors are hard to replace.
