Heat/cooled seat not turning on
Hello,
Thanks for the follow up.I am referring to the heated seat light on the dash.The fan does not start up at all??
Therefore when I do push the switch the light comes on but not the fan.Then I turn the fan by hand and the light stays on.As son as I stop turning the fan,five seconds later the light goes off.
Ls2006
Is the seat cushion duct crushed or kinked?
Hello,
Ls2006
Okay, so at least for now, the ducts are not your problem, the fan is. Please clarify what's been done.
It sounds like it wasn't working, so you say you changed the fan. Exactly how much did you change? (Just the fan and housing, fan plus thermal modules, ...)
Where did the replacement fan come from? (Ford only sells the complete assembly). Do you have anyway to know that the replacement was functional? Maybe your original fan failed and you replaced it with a failed used one?
Hello joegr,
The replacement fan assembly complete came from a Ford dealer.
It looked new but now I am not sure?
I think I got a new used bad fan??
Ls2006
