well i'll be.....so i connected the battery after a few hrs of leaving it unconnected i went through the procedure of what to do after installing a new battery from the owners manual
1. put on parking brake put car in park and start wait until normal operating temp
2. let idle for at least one min
3.turn on AC for at least one min
i took the car for a drive..when i put it into reverse i could tell right away that it didnt shift as hard as it used to i put it into drive and still better then before i took it around the block the gears were shifting better then before i would say a 50% improvement from the way the gears were changing before
i think its still very early to tell for sure if this was the fix i will drive it for a few days before making a final conclusion
