lincolnlogs
im dangerously close to selling this so called "luxury" car.
95,000 miles on it.
2002 LS8 STOCK
valve cover gaskets and seals - DONE
all 8 COP's - DONE
8 brand new plugs
NO CEL - EVER
brand new plugs and cop's, dry plug bellow's, ran good for 5 days (200mi)
NOW....
at a stop light, light turns green.. NORMAL acceleration.. once i get to 1/4+ throttle it acts like ive let off it completely. jam it to the floor it just acts like it would if i was on ice with the traction control. does absolutely nothing. if i let off of it to the 1/4ish throttle range it will pick back up. and if i keep it their to get up to speed(slowly) it is fine and shifts fine. occasionally i can get it to do it when i slam it to the floor it will chug and spit and then take off like a corvette. but when i do that - it sticks in 5th gear and wwont fall out unless i do it manually. and EVERTIME it sticks in gear it STAYS reved up. i will pull it into a parking spot, put it in park.. and it will stay at a steady 3100RPM. shut it off, turn it back on, same thing. next day - its fine, until i try and push it past 1/4 throttle. does it with or without tractoion control on. i cant speed up to pass, nothing. it falls flat as soon as it gets past 1/4 throttle. OCCASIONALLY i can get it to act normal if i feather it past the 1/4... but 90% of the time its a no go. i dont believe its a trans issue because it will do it in park when i try and "snap" the throttle it will rev till i get to that spot and cut completely.
WHAT IS GOING ON?@$%#
95,000 miles on it.
2002 LS8 STOCK
all 8 COP's - DONE
8 brand new plugs
NO CEL - EVER
NOW....
