Fuel rail leak
ToeCutter
East Coast
I've got a fuel leak right at the inlet to the fuel rail. I seems to be coming from the spring lock coupling that sits between the rail inlet and the soft line that attaches to it
I know there are 2 o-rings in the coupling...might this be the cause
it's possible one of the o-rings are nicked - I have run with just one of the two before...
Have you had it recently apart?
Quik, I took it apart when I replaced the VCT solenoid for clearance
when I gave the dealer the part # (9J280)for the coupling , he said that it's part of the fuel line...does the coupling come with the soft fuel line attached, .....thanx
