You would be surprised at how far a little play in the inner tie rod ends goes. Check em out.
Strut rods are a bit of a PITA to change on this car, but not impossible.
Oh, when tightening the cam nut on the LCA to frame, make sure your car is on a 4-post lift or at least some how sitting at ride height with normal weight on it. Otherwise LCA bushings will bind, and have a funny ride and a short life.
If all else fails, check your hub/wheel bearing assembly. Don't forget to replace lock nut if you remove the hub at all.
It very well may be your wheel bearing, I had one, I thought had been changed, but hadn't, it was making a sound like one of the Half shafts was going bad, turns out the roller bearings in my right rear were so worn, they were basically trying to hop over each other; hence the clunk clunk sound.
Have you changed the bushings that hold the sway bar to the frame? Change your oil filter while you're doing that. With those brackets removed, I can actually get my filter out with minimal strain. I know they wouldn't likely cause clunk, but still a good idea.
Just hope it's not like my problem...broken front shock. I couldn't find the damn rattle for the life of me, until my bag suddenly folded one day.
