fitment
95mark8newyork
USA
on my car now, i got the stock 16'' 20 spokes with vogues. im pretty sure the vogues on the car are 225/60/16. I'm looking at getting regular black wall tires (link below)
http://www.tirerack.com/tires/tires...WR6ECDWS&vehicleSearch=false&fromCompare1=yes
My question is, with those tires in that size 225/50/16, will the car sit a bit lower or higher? I'm a space cadet when it comes to how the car's height will increase or decrease based on a tire size. If it lowers it a bit i would actually prefer that, and will that size fit fine on these stock 16s?
well let me refraise that. ground clearance will be lower but wheel to to fender lip will not, it would actually be bigger
i appreciate the help, ill have to think about that, i don't want it to look any higher. last question, would 225/60/16's just leave the car at the same height its at now?
yes it will, as in putting 225/60/16s leave the car at the same height?
If I'm understanding the question correctly, yes, 225-60-16 is the stock tire size for the Mark VIII, so unless you have a different size than that already on the car, going back to 225-60-16 will be the same height.
heres how it works you got 225/50/16 the 225 stands for the width of the tire in mm 22.5 cm. the 50 stands for the sidewall, 50 would be the percent of the width, so you have 11.25cm tall sidewalls, and lets be honest, if you don't know what the 16 are for go somewhere to have them put on...
someone please correct me if im wrong
i know the width, didn't know the middle, and you have to be joking about the last sentence.
He threatens to sue? I see people on here and LOD always say .org - what happened over there?
