Fastbag setup with self adjusting abilities?
Stangman
Project car a.d.d.
Sardinia, OH
Anyone ever conjured up a fastbag setup that takes advantage of the stock features? like lowering while over 60mph, and lowering while parking? Self adjusting for load?
But all the while still have the ability to drop it and raise it quick?
Seems like a wiring mess to accomplish, but seems do-able...
Thinking about it now, stock sensors/solenoids would be difficult to use with an aftermarket setup... unless a tank and compressor was used with stock bags?
I dont know... I'm just thinking out of my arse, I still have a chance to get some A.R.T. bags and throw on my car, but I dont want a 100% fastbag car...
Should not be a problem. All you need is to change the air capacity end of the deal. The electronics can stay the same with the addition of a Module VIII or ASHAM8. The only think you may not get is the instant response of a manual system or if you adjust too far out of range it may error out. Such as going from stock heigh to slammed, if you adjust it may just give error since the range reading is too far out of the norm.
it wont drop quick with the stock 3/16 air lines, to get fast bags you will have to modify the whole system, and lose the factory ability, or you can lower and raise on command and still have the factory air work like it does now, with the above mentioned module 8, asham8, or ray's switch.
Yeah?
and it's probably one of those "having your cake, and eating it too" sort of things...
I'll be able to afford some parts, and not others...
This is probably more of a pipe dream than anything...
