phreakness
Alright well I went to get my car inspected and all the sheet said 'multiple front and rear bushings and / or seals failed." looking under the car yea their right so I've got a friend that has a lift and a little bit of money so I'm going to drop everything finish the rear end and axles and replace all the bushings I can.
I REQUIRE the same ride and comfort that Mark had right off the assy. line with maybe a little more control in the corners.
Here's my list so far.
Lower Control Arm LH MOOG K80053
Lower Control Arm RH MOOG K80055
LCA Bushings MOOG K8680
Strut Rod Bushings MOOG K8659
Front Sway Bar End Link Kit MOOG K8635
Upper Control Arm LH MOOG K8781
Upper Control Arm RH MOOG K8782
Outer Tie Rod Ends MOOG ES3169RL
Inner Tie Rod Ends MOOG EV127
IRS Pinion Brace
IRS Differential Bushings
Front Suspension Support Brace
Rear Cover Brace
F3LY3B477A
IRS Spindle Bushing Kit
Addco 1 1/8" Front Anti-Sway Bar
Addco 1 1/4" Rear Anti-Sway Bar
DLF IRS subframe bushing Kit
N805747S100 IRS bolts
Greaseable Sway Bar Bushings 1-1/4 in / 31.5mm
Greaseable Sway Bar Bushings 1-1/8 in / 28.5mm
Rear End Rebuild
Axles
So do I have everything? Suggestions?
IRS Pinion Brace
Rear Cover Brace
F3LY3B477A
Rear End Rebuild
Axles
