956LS8
So what's up guys its me once again. I'm looking to get a spare key for my ls. I have only one and its missing the Lincoln, stars. Any tips on where I can get maybe two more?
You should get two new keys. You only have to pay to get one of the new keys programmed.
Once you have two working keys, you can program a third one yourself.
If you have three working keys, you can lose or break one of them and still be able to program a new replacement one yourself without having to pay the $100 programming fee again.
Note that on Gen 1's, the remotes *must* be programmed at the dealer. Locksmiths *cannot* program remotes. Sad but true.
Wow. Dealer did not notify me of this. I was charged $102 for one key.
So with two keys, all i need to do is run down to lowes or walmart and cut the key myself, then the car will program it for me?
Really? That sucks. With gen II can you can do the procedure where you cycle the ignition 8 times and it kicks it into programming mode? I did it on the truck and it worked.
...So with two keys, all i need to do is run down to lowes or walmart and cut the key myself, then the car will program it for me?...
Yes. You can program the key yourself. Just follow the steps.
Not true. You can program the fob yourself. Just follow the steps.
Only the 2nd gen cars. I had to have the dealer program the 3rd remote I bought for my '00.
I am sure they enjoyed taking your money. I just spoke to my dealer. You got ripped off bro.
Replacing lost transmitters
If a remote transmitter has been lost
and you would like to remove it
from the vehicle’s memory or you
would like to purchase additional
transmitters for your vehicle (up to
four may be programmed into
memory), take all your vehicle’s
transmitters to your dealer for
programming. It will be necessary
for your dealer to reprogram all the
remote transmitters to your vehicle
while performing this service.
How to reprogram your remote entry transmitters
You must have all remote entry transmitters (maximum of four)
available before beginning this procedure.........
My little local independent locksmith has programmed keys for both my LS and my TC. They can buy a tool/scanner to allow them to do this. He charges $50 for the service, which included cutting two new keys. Call around. Find that retired locksmith that works out of a van like I did. Used him for years. Burtons Lock and Key, Spencer, Indiana. Thanks Bob!
Anybody know where I can get another one of these keys?
If the gen II key will work on gen I cars, get that one instead. Looks 10 times nicer and is easy to find all over ebay.
