Shawn Wilson
Anyone know the location of the Evap canisters and vent solenoid on a 2000 LS?
I wonder if i should change the purge valve first and see if that makes a difference. It doesnt weant to stay running when started
Would a clogged canister be the cause to slow filling at the pump or could it be as simple as the purge valve?It's mounted above the rear subframe. You have to take the subframe off to get to it. Both the canister and the vent valve are there. The purge valve is under the hood on the driver's side shock tower.
What are the most common for filling a gallon a minute
That's what iv heard. Which is why I was looking for the evap can so I could blow it out with some airMost common over all (most all cars) is spiders clogging the vent line.
There are multiple possible causes for slow filling.
This may fill in some of the details from the diagrams: 2006 Lincoln LS Workshop Manual
