Can't be done; it fastens to the header.
I forgot about that, but was quickly reminded when I had it on the lift today. Anyway, got it done. I would not want to have done this without air tools, torches, lift. Here are a few pics, also did the EGR valve while I was there, I know my luck I would find out it needed to be replaced after everything was back together, so I was not taking the chance.
Here is my run down,
1) Took off wipers
2) Removed cowl covering
3) Removed wiper motor and linkage as a unit with rest of cowl cover it attaches to.
4) Ah, now I can see theEGR valve and tube
5) Loosen and remove nut to EGR valve from EGR tube by turning the wrench over on each turn since not much turning radius with the wrench available, find that the nut is seized to the tube and the whole tube is turning, so I remove the EGR with top 1/2 of tube connected to it since it broke the tube all the way turning it (see pics). Now remove the tube from EGR by spinning, would not spin in car, was wedged against firewall the way tube is contoured.
6) Heat up the nut on the EGR tube to cat. converter connector and remove it.
7) Remove lower portion of tube
8) Decide to order a new EGR valve since I have it out and dont know the condition of it.
9) Put in new EGR valve
10) Slide EGR tube down behind engine and thread the nut to EGR valve
11) TRY to get nut caught on converter end, cant get nut to catch, seems like tube is not bent 100 percent correct, sooooo strip fitting on converter, ARRRRRRG!!!!!
12) Heat up converter and remove fitting, repair threads so screw on tube
13) put it back in, fight with it, finally get it to all catch and secure everything and reinstall everything. AHHHHHHH!!!!!!
So, all I can say is it deffinetly can be catogorized as a PITA!!!!!!
The new tube does not have the flex part in it like the old one, so I am sure that added to the difficulty here.
